i got wood, i also picked up some lumber lololol wood puns... love em
measured the board a little short but it still fits may need to get a few screws that are a little longer than recomended,
picked up some pre stain and some stain while i was picking it up,
started off by drawing on the board with a pencil. this way i could be sure i had sanded a layer off, if the leads gone the woods gone.
sanded it down with 80grit then again with 120 grit. applied the pre sealer, let id dry for 5-15 mins. about 8 id say then threw on the first coat of stain, now waiting the recomended 2 hours before the second coat, its currently just sitting on a table out in the yard. once its dry ill lay the blocks down and mark my screw holes and get to drilling.
board is about 20mm thick so I'm only going in 12mm with the bit. this should give me plenty of room for the scres to bite into,
using the 5/64 bit taped uo at 12mm
only waiting on M2*10mm grub screws for attaching the side rails to each other and the coupler, and she be ready to haul!!!! I'm so excited
