HW Max 6 G2 - Replacement Fan
ridgehead44
North Texas
Hi all,
My Max 6 G2 fan was DOA. Never run it, but it doesn't turn on when I plug in the system. It looks like the stock fan is a Cyclone 3510 CL, but I've not been able to find a match online. Has anybody had to replace their Max 6's fan, and if so, what did you use? Thanks in advance!
The Max6 G2 ESC fan doesn't turn on when powered up. It turns on at a certain temperature. It's not broken.
Was just about to say that. Although it should to a self test on power up and turn back off, and won't click on until the esc temp reaches a certain temp, (per esc settings)
Most Max6 G2 owners replace the fan with a Rocket 35mm & run it into the receiver in an open port to run when powered on & throw away the supplied one to bypass the temp lock. Stocker will come on after running & the ESC heats up. Temp is unknown. Some say 150, some say 170. I am not privy to this information.
My Max6 with piggyback 35mm Rocket over caps & stock fan. Rocket runs full time & lowered ESC temps 15° & stocker will run & turn on/off. ESC stays cool during extreme bashing & 90° outside temps.
:facepalm::facepalm::facepalm:
Well, at least I didn't throw it out. Thank you so much! I'll drop it back in this weekend. Thanks again, everybody!
