I have installed the nitro racing clutch but now I am confused. To be expected for an old fart my age. It works like a champ. I set the clutch in the pins in the normal position. I see there is two other settings I can use but don't understand what they will do for me. In the center holes it says the clutch will engage at higher RPM's for more bottom end. In the third set it says the clutch will engage at higher RPM's an even more bottom end. There is also a picture of an area that needs to be cut out of the clutch with a hobby knife. I know many of you have installed one of these clutches. Could I get one of you to explain this to me so I can understand what the benefit of each setting will do for me?
Much appreciated.
B/T
Much appreciated.
B/T
