How to charge 6 batteries at the same time
cfranko
Hey everyone, I have 6 batteries. 1 of them is 2S Lipo and all the others are nimh. Can I buy one charger and charge all these at the same time? Currently I use a cheap wall adapter to charge all of them one by one and it takes ages so I need a solution. Thanks for the help.
Welcome to RCT. Yeah but it won't be cheap. They make quad chargers. So you can charge (4) at a time. What are the nimhs for. Any reason for them. Or just what you have. I own a couple chargers the venom quad and a hi tech.. witch together about $4- $450.. i would cheap out on the chargers IMO.. don't need any problems with that lipo...
I just have the nimh's lying around, Quad channel chargers are really expensive. If I get a dual channel charger can I fill up 2 nimh's at the same times quickly? As I said currently I have a cheap wall adapter and it takes ages, the nimh batteries I have already make the car go pretty fast so I don't think I need lipo batteries.
Also, I tried charging my only lipo battery with this but it didn't really charge, am I doing something wrong?
You definitely need a lipo charger. Or your lipo will end up going bad. Those should be balanced charged and at a certain voltage.. you can get a dual if you want. I would charge in series or parallel. Not the safest thing to to
The wall adapter isn't a good to use on your lipo
An iMax B6 or iMax X100 or B6AC Pro fits in my budget, I don't know which one I should get.
The iMax x100 is $100. Spend a bit more and get a better charger that does 2 packs at once and will be enough power for you down the line to charge a couple 6S packs pretty fast or well matched lipos in parallel.
https://www.smc-racing.com/index.php?route=product/product&path=113&product_id=541
I have a few chargers, but if my dynamite 4x100w/4x10A dies on me, I'll be replacing it with a couple of the "DC" only versions of that charger as I have a couple 12V PSU's in the closet. The people that have the AC/DC version really like it though.
