how do i post pictures?
what the **** am i doing wroung!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1111
help me plz give me a step by step thing iam a damn dumbass
o duh. u have to right click on the picture when ur on this page https://www.rcnitrotalk.com/gallery/showphoto.php?photo=5202&papass=&sort=1&thecat=500
then u right click on the picture... then click on Properties.. then triple click on the url/ Address in the properties window it should say this https://www.rcnitrotalk.com/gallery/data/500/1831DSCN75341.jpg then while its highlighted right click on the highlighted address and go to COPY
then u come here to the post click on submit reply, then click on the IMG box, a window will come up. ONLY right click and go to PASTE. then click OK. then click Submit reply and we should all see this-
later
1. Go to your image in the image gallery.
2. Right-click on the center of the image.
3. Select "properties" from the menu that pops up.
4. Highlight the link for the picture and hit ctrl-c (or right click and hit copy)
5. Come back to your thread where you desire to post the image.
6. Type: [I'm*G]
7. hit ctrl-v (or select paste from the edit menu)
8. Type: [/I'm*G]
Then you are done. Just make certain to remove the asterisks from between the M and G in both tags.
The end result will look like it did in my last post.
Ok, you got it loaded into RCNT ... that's good. Go to your gallery ... yes it's there because I can see it.
Click on the thumbnail so you can get the actual sized pic.
Right click on the pic to get the properties, copy the URL address
when you go to post the pic, click on the IMG tag in the vB Code section of the reply page. it sould look like this
url]
I added spaces in the IMG tag so you could see it. If all is done as instructed it'll show up like this
no on the picture, u see the picture of ur savage? put the mouse over it. then with ur finger click on the right side of the mouse, move the mouse so it goes over properties. then click on properites using the leftside of the mouse. then a screen should come up. over to the left it will say ADDRESS {URL} and to the right of that there should be a address. using the left side of the mouse, click 3 times quickly and the whole address should become highlighted. then while its highlighted, using the right side of the mouse and click on the highlighted url then go to COPY and click on that using the left side of the mouse. then go to submit reply then click on the IMG box. using the right side of the mouse, click and go to paste, click on paste using the left side of the mouse. then click OK using the left side of the mouse. then move ur mouse over SUBMIT REVIEW and click using the left side of the mouse.
later
Pissant, I spelled it out for you and you still screwed it up. Read the part where it says to remove the asterisks from between the M and the G. You are almost there.
iam doing what you are saying i can post it but can't get it on the thread wit the picture, iam sick of this GOOD NIGHT!!!
I DID IT!!!!!!!!!!!!!!!!!!!! I did use the wrong (URL) thanks guys, i love you!!!!!!!!1 :hi:
one more question, can i make my picture bigger??
no problem thats what we are here for. so whos info was easier to understand? my totally spelled out step for step info?
later
it was urs maxx trooper, you said i was using the wrong address and I WAS!! :bored:
Told you you could do it. Just gotta calm down and step back sometimes.
:OT: That's one of the best lines I heard in my frustrations of learning how to use a Starter box. Thanks Nitromaniac!
The only way to make the picture larger is to post a larger picture in your gallery. If you can not do so, then you will need to find a host for a larger picture.
