hi guys,need your help!!!
harry
RCTalk Racer
ni
hi guys,
i only got a new car yesturday its a thunder tiger ts4n it was second hand but in realy good condition.So the car was starting ok lastnite but this morning shes not starting.i was trying to start the car all day but she only started a few times but when i press the speed button (throttle) she cuts off i tryed to start it again and again but she wount start.So if any1 knows what might be the problem please help me.cause my dad is just about to kill me cause i didnt even got to drive the car yat and she is already broken. as it was raining all day and it was so wet.
GUYS I REALY NEED YOUR HELP!!!:\:\:\
hi guys,
try starting back at factory settings. Hsn out 3-4 turns from fully closed, lsn flush with the end of the carb barrel. That should get it started. Or very close. Adjust idle, and let er rip!
thanks for taking your time and helping me but could u give me more details on how to do that please as I'm from lithuania but i live in northern irerand and its abit hard for me to understand english.
thnx
Also check to see if you have burned out the glow plug.... First make sure the top of the cooler around the glow plug is clean.... then remove it and attach it to your glow starter and see if it lights up.... If not you need to replace it. If your carb settings are not right these can burn out easy!!
Good luck!
hey harry, I'm running ts4n's for about a year and a half, I'm from the republic of ireland (cork), pm me if you want any help or info.
DAve
