SteelCityNitro
- Thread starter
- #21
It absolutely HAS to be connected to the computer to show the error code. Without that, you can change parts for days without a solution.
Do NOT go to a mechanic without the proper testing equipment. You'll be wasting time and money.
You can also disconnect the battery for 10 minutes so your car's computer can reset itself. It will probably run perfectly for several minutes. If it goes back to the same problem it IS a sensor. Nothing else.
Hm, that makes sense Rolex. However, I did just put a new battery in it and when I was replacing it I actually removed the battery and took it with me to bypass any core charges. When I came back and put in the new one about 30 minutes later I didnt see any improvement.
