No need to bump when you are already at the top of the page.
A drill is more than enough to start your engine, even at a lower rpm. All it takes is a good compression stroke to get it started if you have a good tune. Is it priming? If not, hold your finger over the stinger while turning it over. Once you hear it start to catch, remove your finger. If you flood it, tip it to run any unburnt fuel to the front of the exhaust, then tip it out of the hole. Then loosen the glow plug and turn it over for a second. Tighten it and try again.
