so i recently relocated all my electronics....i put the esc on the rear axle and the rx on the top link...over all i like this set up but i have a problem with it...since it has taken some of the weight off the top of the chassis it makes the ass end tippy when i go over a ledge after comparing with a completely stock MRC i found that there just isnt enough weight on the shock to let it compress the spring....so instead of flexing it just turn itself over...sooo....i did a little test and removed all the springs and it did much better...but having no springs at all produced a few bad results too...at times the axle would follow the contour of the rock and keep a good bite on it....so here finally is my question....i need some really soft springs for these mrc shocks...i want them to be just soft enough to barley hold it up....but i have absolutely no idea which springs are soft and which are not as compared to the stock springs....i appreciate the help guys....thanks a bunch...
