Help with Hobbymate D6 duo pro 🤷
Cheez ‘n’ Quackers
  3. Crawling
Anyone have this charger and come across this? I’ve done factory reset and no matter what I connect I get this message.
not familiar with that charger, but I've had random "connect errors" when I have a faulty cable, I always keep spare cables and balance leads, sometimes it's a bad internal wiring on the LiPo pack too!
1) swap batteries and verify
2) swap wiring and verify
Good Luck!
Good Luck!
I don’t think it’s battery wires or balance leads. I’ve connected several different batteries to channel 1 and all work perfectly. Trying the same on channel 2 I get nothing. This all started after I used the “ power supply “ setting at 12 v To power a Hudy vac.
sounds fishy to me, hope you didn't blow out the port... for 12V I just pull directly from my power supply for my tire warmers, etc..
That’s likely what happened. 12v power supply is one thing I don’t have on my bench. That’s now on my shopping list along with another charger.
A good bench top power supply can be had for $53 off of amazon. Its not powerful enough to power DC chargers but will power just about anything youd want to test/power on your bench. Theyre variable voltage up to 30V and will put out up to 10A. Its what I use. LINK
Anyone have this charger and come across this? I’ve done factory reset and no matter what I connect I get this message.View attachment 167224
Try lowering the cell voltage to 4.2 and see what happens. I have seen this on mine also...I forget what it was but I think that may work for you. Curious to hear if it does...
