johnsland8
I have a XXX-NT RTR version w/ a Mach 15. When I pull on the starter, fuel does not get sucked into the carb. I can drop a couple of drops into the carb and get it started and as long as it is set rich enough it will keep running. If I lean it out or it dies, it will not restart unless I drop fuel into the carb. I have replaced the fuel lines and the tank "appears" to be sealing although I have not pressure tested it and I see no obvious leaks. Again, it will only run if set very rich otherwise it will die when I hit full throttle and release quickly. It will also die when I hit the brakes although I cannot see the carb opening actually change, I have it set open correctly w/ the idle adjust screw...
Any ideas?
Thanks,
John
Any ideas?
Thanks,
John
