pedcam1356
hi i got stuck becouse I'm new to rc but imgoing in to this hobby to the full i bought a mta4 having a .28 engine ...
as i turned this truck all in metal alloy titanum and added a rollcage to this truck is heavy the .28 is still doing good but i would like to change and as I've been trough some researches i found 3 engines to choose from i guess these are close to best i think but i need help to choose the right one for the truck and I'm hope you can help me on this and as everyone I'm looking for the best acceleration and top speed .... so here are the models and specs
HPI Nitro Star K4.6 HO Engine w/Pull Start HPI15204
Displacement: 0.28 cu in (4.59cc)
•Bore: 18.6mm
•Stroke: 16.9mm
•Practical RPM: 3,100 - 39,500
•Maximum Horsepower: 2.95 hp @ 38,000 rpm
•Maximum RPM: 41,000
•Carburetor Bore: 9.0mm with 8.0mm and 8.5mm reducer
Associated AE 8.0 Engine: Monster MGT 8.0 ASC25480
SPECS
• Displacement: .50 cu in (8.0cc)
•Specs such as horsepower, bore and stroke were not provided by manufacturer
•I've serched some say around 15000rpm max
Axial 32RR-1
Size
.32cubic inch/5.2cc
Maximum RPM
37500 RPM
Bore
19.5 mm
Stroke
17.5 mm
Construction
ABC (Aluminum Brass Chrome)
Heat-sink Head
Axial black anodized
Carburetor
9.0mm composite slide carburetor (includes optional 8.0 & 8.5mm venturi’s)
Carburetor Adjustments
3 Needle, Flush Settings
Case
Black aluminum, rear exhaust
Connecting Rod
Dual bushing
Sleeve
6P
Starting system
Pullstarter
Recommended Glow Plug
Cold-5 power plug
•Bore: 18.6mm
•Stroke: 16.9mm
SPECS
Axial 32RR-1
Size
.32cubic inch/5.2cc
Maximum RPM
37500 RPM
Bore
19.5 mm
Stroke
17.5 mm
Construction
Heat-sink Head
Carburetor
Case
Connecting Rod
Dual bushing
Sleeve
6P
Starting system
Pullstarter
Cold-5 power plug
