Brand new never opened.
Green Head
Pull Start
175.00 + Buyer pays actual shipping costs.
Step up to the plate today and put the Axial 32 Spec 1s engine into your favorite basher! Axial engines include ABC construction, Composite 3 needle carburetor, 8 port design, reliable pull start, and incredible performance! We use the highest quality materials and the latest CAD and CNC techniques to maintain the maximum quality level possible. Axial engines are also dyno tested to ensure the best level of performance possible.
The 32 Spec 1s is a .32 cubic inch big block engine featuring a machined cast aluminum heat-sink head for extra cooling, dual bushing aluminum connecting rod, true ABC chrome sleeve construction for durability, and a three needle 9.0mm slide carburetor (including 8.0 & 8.5mm optional venturi’s) with a composite body for better performance at higher temperatures. The carburetor features a factory re-set line on the high speed needle, and flush needles making re-setting, to baseline factory specifications, quick and easy. There is also an optional Turbo Button head available.
This is a direct bolt-in replacement engine for any .21+ engine mount, and will accept most aftermarket shaft drive starting systems.
Engine Specifications
Size .32cubic inch
Maximum RPM 34,000
Bore 19.5mm
Stroke 17.5mm
Construction ABC
Heat-sink Head Grey Anodized Aluminum
Carburetor 9.0mm Composite Slide Carburetor (includes optional 8.0 & 8.5mm venturi’s)
Carburetor Adjustments 3 Needle, Flush Settings
Case Black Aluminum, Rear Exhaust
Connecting Rod Dual Bushing
Sleeve 8 port
Starting system Pullstarter
Recommended Glow Plug Cold-5 Power Plug
Green Head
Pull Start
Size .32cubic inch
Maximum RPM 34,000
Bore 19.5mm
Stroke 17.5mm
Construction ABC
Sleeve 8 port
