help i turned the screw i should't have
ALLHYPEDUP
got my self a hyper 7 and i have turned the mid screw on the carb....i know what i am...... ok.......now it won't rev.......how do i go about resetting it ...please help
just make it flush with the carb body. then your lsn will need some tweeking to get it back in tune. no biggie. easy fix.
will this help with my reving problem or is it something else that is causing that
You're getting a bad mixture which isn't letting the engine rev up like it should. Just like CorradoPsi said, just set the MSN back to flush and you should be fine.
At most, you'll have to re-tune the LSN and HSN.
reset the needles to factory settings and then try to run it....we'll be able to help better once you're at a base point to go from.....
When I have trouble tuning, I go back to factory settings, then I tune from there and it always works. And you dont need to be afraid that your car will take off from you if your lsn is way lean.
so where do i find what the factory settings are ...i must sound like an idiot
Most Nitro motors or car kits come with instructions, they should have the factory settings
If you can tell us what motor you have, I am sure some of the Members can provide the information you need
Alternatively go to the manufacturer's web page and see if they have it in an electronic (PDF) format.
If they do not have a link to the manual, drop them a mail.
just put it back flush. That one that you turned is not a needle like the novarossi. That is the seat for the low end. If you are running a hyper change the tank to a mugen. I was having a problem of no matter what engine I put it, it did not do anything different. Come to find out from the ofna message board people are putting mugen tanks in them. I even put a brand new hyper tank in and they told me to get rid of it. I went to the mugen tank and man what a difference.
