Help! Hobbyzone Apprentice S First Flight Gone Wrong (beginner error)
TurboChargedHonda
So I have driven RC cars for years and decided to check out the sky side of the hobby. I chose the Hobbyzone Apprentice S as my first plane (I know its kind of an old-ish platform but chose it because it has good parts availability to me). I am a complete beginner in RC planes, so please give me some tips on how to take off and land, and repair the plane. Some more info about aftermarket parts and other
I turned it on and made sure the Safe was calibrated with the plane on flat ground. The day was calm, with a little wind blowing (average California climate). I first attempted to take off from the grass but found the tires too small, which flipped the plane forward onto its propeller. Take 2 was to start on the clay part of a baseball field and fly over onto the grass. It was able to take off into the air, but it wasn't the best start. There was very little distance for it to take off, so I pushed hard on the throttle, which made the plane go up a bit too steep, and right before it lifted off, one of the wheels hit a base on the baseball court (it was a plastic one protruding from the ground). Didn't go too well from there. From my past experience of driving cars without any gyro assistance, I tried to correct the plane as the gyro was doing the same thing. The plane had already gained altitude (of about the same height of a redwood tree or tall pine tree... near where I was flying), and I was still trying to gain control of the plane.
End result: It crashed on its nose towards to left upper side of the plane (forgot to hit the panic button). The first thing I noticed was the smoke. It was the battery. When I got there, the whole battery compartment had fallen out of the plane (including the plastic part that was supposed to be in the fuselage), and the battery was disconnected from the ESC (got pretty lucky there!). That allowed me to save the rest of the plane before it went up into flames.
From the damage inspection, the battery cover was burnt and deformed, and the plastic battery compartment was also scorched (damage from the battery fire). The things that actually broke from the crash was the propeller (bent and partially snapped at the base of one propeller), a deformed motor mount (not broken, just warped from the force of impact), and the wing had a fracture on the left side right by the plastic brace for the rubber bands.
For the wing, should I mend it with Beacon Foam Tac, or do I have to get a new one (I would like to know if it is too damaged to be fixed, hopefully not). Also, I have lost (or broken) one of the rubber band holders, can I only get it from a new fuselage? I am able to find the battery cover, but I am having a hard time finding the plastic frame that has the battery velcro strap attached to it. Do I also have to get a new fuselage in order to replace it?
I would really appreciate any help! Thanks in advance!
btw: some additional beginner tips would also help a lot!
I have included some pictures below:
Tunedpipe
RCNT Addict
Military Veteran
Somewhere.
Bashing
I am the worst person in the world to except advice from when it comes to toys in the air. I am new also and already have had my share of crashes. I will however highly recommend this....
BobP
RCNT Addict
Where you least expect me
Bashing, Racing
Get a good supply of foam epoxy and learn how to use it. I glued mine together probably 10 times before I had to get another body. Then I just bought the $99 RealFlight basic and learn how to fly with it. So I agree the best way to learn is on the computer
TurboChargedHonda
Thanks for all the replies! I really appreciate it! I will look into the flight simulator. Also, is there something else that I can do other than a flight simulator that I could try to get better at flying (one of the reasons that I like RC is because it gets me out of the house, so having it on a computer kind of defeats the purpose)? As for the plane, I have ordered some foam tac/epoxy, another propeller, battery tray, motor mount, and a new battery. Hopefully, I can get the plane up and running by the end of the week.
hamz9561
Proud Short Bus Rider
Military Veteran
In a padded cell
Bashing
A sim is good for when you can't get out to keep the "hangar" rust off. A wise old pilot once told me that there are two types of planes: Those that have crashed those that will.
I've had my fair share RC aircraft crashes. I had to learn to pick up the pieces and laugh at myself and hopefully learn from the crash and try not to do it again.
TurboChargedHonda
I might go with the RF9, since all of you guys are telling me to do that. I did some research, and it looks like there is one with a transmitter and one without a transmitter. I have the Spektrum DXe transmitter, so does the DXe work on the software if I get the right cables (also, what is the right cable if it works), or does it only work with the specific transmitter? Again thanks for all the help, I really appreciate it!
AClegg
RCNT Talkaholic
Central California
Racing
I practiced on a flight simulator. It was back in the early 90s. I felt I was ready to take my first flight, so I took my plane out, which took me about a month to build out of balsa wood. Fired it up and lunched it by hand. I flew it straight for a few yards then decided to start climbing. I got about 40 feet up and the engine stalled. It hit the ground, nose first. The motor and plane were completely destroyed. It was at that point I decided I should stick to racing RC cars. There was a lot of time and money that went into that 5 second flight.
Maybe, now that there are electric planes, I'll give it another try.
Rolex
Hoof Hearted
Staff member
Military Veteran
In my recliner
Bashing, Flying
Any Tx will work with the sim through the provided cable. The advantage of this is that you also get familiar with the exact controller you will be using when flying outside.
TurboChargedHonda
Thank you for the clarification! The cables that I am able to find are all not compatible with Real Flight. Is there a part number or a link to it? Again, I really appreciate everyone trying to help!
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Thread starter Similar threads Forum Replies Date
darkslayor24 hobbyzone supercub help!!!! RC Aircraft 9
L I have to design a super fast with low kv motor and a nimh 8.v battery! help please! Electric RC 2
Kamina724 Help with tires Electric RC 8
H Help finding car manual? Electric RC 5
H Please help me identify my RC. Nitro RC 3
T help with 12th tribute build On-road and Rally Cars 0
Oldblue "Vintage" Losi LXT revival help needed Stadium Trucks 2
N Help with foam plane model RC Aircraft 6
Connor_TK.Extra Need help choosing Electric RC 5
T Fantom FR 15 engine help Engines 9
B Stinger strut help RC Boats 15
J Mgt radio/receiver help! Monster Trucks 31
Connor_TK.Extra Need help choosing car Electric RC 13
jlobbia Need help finding a pull start for the sc10gt Nitro RC 1
jlobbia Need help identifying associated nitro short course truck Nitro RC 3
W Shock Help Short Course Trucks 10
T I’m new to rc cars and need help Nitro RC 7
CameronCodes BROKEN SERVO!!! IN NEED OF HELP!!! Electronics 12
S Please help identify nitro buggy Nitro RC 5
Simonh080 Need help with my hyper 7 nitro Nitro RC 19
NurturantQuasar Help scx II body mount kit RC Rock Crawlers 0
G Kyosho inferno neo 3.0 nitro engine help Engines 4
hoopdoggy I need help with my nitro HPI rs4 mt Stadium Trucks 30
D Can anyone help identifying this chassis?? Electric RC 2
Bienfang Help...my nuts a falling out! RC Rock Crawlers 10
H Help Me Identify This Car? Nitro RC 4
J Help with first Losi please!! Electric RC 14
NurturantQuasar What are ways to help keep sand out of slash 4x4 Electric RC 5
N Need help finding battery Electric RC 11
themask888 Help help. Orlando FL Nitro RC 21
Z Need help identifying this nitro engine! Engines 10
dpderr Can someone please help me identify my Losi 8ight? Buggy and Truggy 5
The Undertaker Servo help Electric RC 16
R Hyper 7 end point adjustment HELP Nitro RC 3
Sycko Hi All, Can anyone help with one way bearing? Nitro RC 12
jlobbia XTM 457 Pullstart Help Nitro RC 7
B Help with tyro 79 RC Aircraft 0
L Nt-16 cen gx1 help needed Nitro RC 4
Connor_TK.Extra Need help with parts for my nitro HSP bug crush RC car Nitro RC 15
P T maxx identification help Nitro RC 2
Connor_TK.Extra Need help with shredded cluch bell Nitro RC 12
W Dug out my old Nitro buggy, need help, it's been so long! Nitro RC 1
R Rocker arm help? Please Electric RC 7
RookieNumberss Need help identifying what appears to be a bottom of a shock Suspension 5
1cowabunga Please help with battery / charger question Electronics 3
Freezectrl I've been working on this Savage 4.6 for 3 weeks and I can't get it running, help! Engines 18
T Need help ? Buggy and Truggy 4
J Help. Need HPI motor mount 86000. Nitro RC 0
Mcrzeus Newcomer needing help with first boat RC Boats 13
T PLEASE HELP ME decide what to get Electric RC 3
