canderson4
Hi everyone, I’m working on my first RC plane build for a school project and was hoping to get some feedback before I go too far, mainly just want to make sure it’ll actually fly
If anyone has any tips on making sure my general proportions and size is reasonable, or if there a good guidelines to follow for a simple, stable trainer I would really appreciate it. I am currently doing a wingspan of 77cm with a fuselage length of 57cm. I used calculators to help with other dimensions but I changed them a bit because they didn't seem right. I am also aware that 77cm might be a bit short. Would any of this deeply effect performance? Or will it still be able to fly if I get the balance right? Basically, how bad does a design actually have to be before it straight up doesn't fly, should I spend more time working on a guaranteed design, or just get into building and figure it out as I go?
I am also not doing an elevator or rudder, I am going to double the ailerons as elevators, if anyone has any tips for this type of design, or things I should keep in mind, I would really appreciate some tips. The calculators I used all included elevators and rudders, so how does the combined ailerons and elevators change the design? Should they still be toward the end of the wing, or closer, shorter? wider? etc.
Finally, whats a good way to get a well balanced plane, most of the advice I have been given so far is to make sure I balance it right, general tips or advice on this would be helpful.
I included a picture of my rough design below, does it look right proportionally? Any tips at all will be deeply appreciated! This is very new to me.
Thank you!
Thank you!
