Have a problem.
duramax47
The turnigy lipo batterys came intoday and they have 8 gauge wire which is huge, is it okay to solder them up with deans, i ask because where they need to be solder from the wire to the deans tip doesn't make sence because and may be hard to solder because the wire is so big and the deans tip is so small.
Help asap I'm doing this today so i can run it.
Yes you can. You just need to tin the wires and then tin the Dean's plug. Heat the wire and set the plug against the wire.
I solder both them up and 1 took a charge and the 2nd one the charger says stop like their is somthing wrong with battery number 2 any idea's
