- Bomb Pop Island
- Racing
So today I got in and installed a lot of parts. I got the rpm caster and rear hubs for the slash. Rpm rear shock tower and bumper mount. Also I will order another set of the screw pins because they are the original pins in my slash and a couple of them are a little bent. Also going to order a 12mm aluminum hex hubs because I always have a problem with the stock ones. I will get the hobby park ones cause those ones they have a 1.5mm grub screw to screw in to lock the pin and hub in place. And my slash is 6 years old and most of the stuff on it is stock. Now driveshafts. Still have the stock plastic ones. They don't rotate as freely. I know that the Traxxas metal ones are around $80. I'm looking for something cheaper. I know that the tekno driveshafts are good. There is another brand but I don't know the name of it. Also I am thinking about getting into the trans and diff. I never been into it and again it is still stock. The only thing I did with the trans is change out the spur gear with another one. Also I am going to re grease the diff and just check on all of the gears. With the rustler with the driveshafts and trans it is all good cause the car is only 2 years old vs my slash is 6 years old. Also forgot to mention I got a bearing kit for the slash. Next for both cars is brushless systems. Probably going to go with a hobbywing system.
For the rustler i am still looking for a servo horn and for the slash still looking a set of shocks. Or I might try to rebuild all of the shocks I have.
Also just thought of the name - MIPs shafts are good as well.
