It's good out of the box but there is one weak spot. The rest of this is performance oriented.
For performance this should help, just remember this is ALL Traxxas part and there are other options.
https://traxxas.com/news/maximize-trx4-sport-performance
Must Do
Servo Horn
If it's got
the plastic servo horn throw it in the trash and replace it with aluminum while you assemble it. Mine stripped after the first 10 mins of running. Spend $10-15 and save some disappointment and wrenching later.
Better than Stock, but not Required
Wheels, Tires and foam
This is biggest performance upgrade in my book. The stock wheels are functional, but lack in performance. You can spend a ton of money on fancy SSDs or Vanquish wheels. As a cheaper alternative you can go for the knock offs. I use the Injora 1.9 Bead locks. They have an array of styles and a fraction of the price. Do they perform as well, I have no idea, but they are much better than stock. The downside is they don't have a brass ring option, if you want that.
https://www.injora.com/collections/1-9-wheels
For tires, Proline Hyrax Predator compound for the sticky ones or G8 for longer wear. I'm running the JConcepts Ruptures now, but I feel the Hyrax is better out of the box.
You can also modify the stock tires and save some $$.
The foams make a difference. I'm running proline dual stage foam. It's good but I think there might be better out there.
Adding Brass
If you add brass, buy the name brand. I bought some brass off Amazon and it didn't fit right ... at all. I ended up sending it back and buying Samix brass. It's more expensive but bolts right one with no fuss.
If you add weight (brass) to your wheels, it can strain the motor. My rig is about 9-10lbs, so keep that in mind and don't go crazy unless you are upgrading everything.
Battery Tray
On the non-sport versions there is a forward battery tray above the front axle. It's either Traxxas part number 8080 or 8080X, depending on what fits your rig. This creates a forward weight bias that is good for climbing. 60/50 forward bias seems to be a good number.
https://traxxas.com/products/parts/8080
https://traxxas.com/products/parts/8080X
You can make one yourself with some ABS plastic or 3D printed parts. Again trading $$ for labor.
I use a Protek or gensacearespammers battery, and they fit fine. Just watch your wires to make sure they do not rub.
https://www.amainhobbies.com/protek...po-battery-11.4v-4800mah-ptk-5116-22/p1370771
https://www.amainhobbies.com/gens-a...onnector-11.4v-3600mah-gea36003s60x6/p1336182
Servo
The stock Servo is OK and there are other ones out there that are better. If you want he mother of all servos, us the Protek 1KBL.
https://www.amainhobbies.com/protek...s-waterproof-crawler-servo-ptk-1ktbl/p1331854
If that's too much or not your thing, anything metal gear, water proof and high voltage capable is an upgrade. Francis from RC Review does some testing. I personally can't stand the Savox, they talk way too much for me.
BEC
If you want an external
BEC I would not recommend the Traxxas unit. It only gives you more current to for things like lights. An upgrade in voltage (
check your electronics can handle it) will make your servo stronger and faster. You will need to to some work on the install, but you get a better product.
Note that if you have the lockers and/or 2-speed trans the baby servos don't like more than 6.0V and you will need to wire around them. This my wiring.
If they are on your rig, you can upgrade the baby servos, with Yeah Racing which can handle 7.4V.Personally I don't know that it's worth the hassle and just worked around them with a new
BEC.
https://www.yeahracing.com/waterproof-micro-servo-for-traxxas-trx-4-trx-6-ye-0030-00085735
Steering Link
After I added my brass I had less steering angle, because of the cover. I installed the Hot Racing steering link and got it back.
https://www.amainhobbies.com/hot-ra...offset-steering-tie-rod-hrastrxf49m08/p733464
This is the factory link is tight on the factory covers and it gets worse with brass.
The Hot Racing link
Bonus parts
Motor & ESC
The Titan motor is OK, but if you burn it out and want an upgrade, you can move to Holmes Hobby Trailmaster. It's about the same price as factory and better performance.
If you want to upgrade the ESC and stay brushed the HobbyWing 1080 ESC is a good choice. It's like $50 and far more capable than the stock one.
If brushless is your thing then the Hobbywing Fusion is a good choice.
Radio
This is really a nice to have and not required in anyway. If you don't have the lockers/2 speed trans, you might look at a radio upgrade. The TQI is Ok until you need to adjust something in the field. Without the magic manual impossible.
Mods
Bumpers
The front/rear bumpers are huge and limit your mobility. You can either remove them or modify them. I flipped the front and rear bumper mounts, trimmed the body and modified the bumpers to tuck every thing up tight.
Rock Slider Tuck
You may want to tuck the rock sliders up into the body a bit more and Traxxas will gladly sell you a kit and 3x18 mm screws
#2583 for it.
https://traxxas.com/products/parts/2539
https://traxxas.com/products/parts/4365
However, I went to my local hardware store and bought the material for about $3 with no shipping cost. It did take a little bit of filling to get it all to fit correctly.
