Going to upgrade my T-Maxx steering servo and Servo horn
Just of the climb settings and now it will not I will not do anything that would try to run that's it have to say it back to factory settings
You don't actually run an engine at factory settings ,its merely a setting after break-in has been done to start
a fresh tune!
Factory sets are too rich ,an you need to watch a fine tune vid. that has been posted!
A fine tune vid will show you how to adjust your HSN & LSN needle settings by step by step ,
an show how a running engine sounds when making those changes!....:cool:
Clean the carburetor last night was a lot hard little bit trash in the carburetor
Pretty much got back to factory settings two and a quarter turned out 2 1\4 of Hi-needle
Now have to set the idle Gap
Now have to set the idle Gap[/QUOTE]
Welcome to the world of RC nitro maintenance!.....:p
Yeah, that's a 1.5mm grub screw if I remember right. Usually, once I remove it, I replace it with a good 2.5mm cap head screw as the threads are the same. Then I don't run the risk of stripping it, or if I do, I have a head that I can still grab on to with pliers.
Okay but still didn't answer my question the carburetor arm which way which way is it supposed to Face
You didn't ask. Your wording made it sound like you were having a hard time getting it on or off, not in the right position.
Having issues getting the carburetor arm in the right position for linkage the little arm or barrels has a set screw in it
This is how the linkage should be lined up and you can see which way you should point the throttle arm on the carb:
I adjusted the carb gap at little bit better and adjusted the idle screw it does not died when applying the.
brakes now but when start giving the full throttle a starts to Bob down and the hit full throttle lot open it is
kills it and to add throttle is applied and let and letting off of the throttle it still revs up
It bogs down when you accelerate to Full Throttle and approaching Full Throttle it is stalling out and and it never issue is when you give it throttle and back off the throttle it's still going
Remove nitro motor and check it over a couple of pipe for the muffler was loose fuel filter was dirty and clutch shoes look good what a lot of clutch dust reset carb to break in specs
