Okay guys I received the Go engine in the mail today thanks to an awesome supporting member on here working with me. This is just an initial visual inspection in comparison to a brand new Traxxxas 3.3 engine. At first look, the material quality looks to be of better quality than the stock Traxxas engine. I would compare the block to be similar to the Picco maxx series engines. The engine does not come with a glow plug installed. The plug is a standard plug non turbo. Looks like the pull starter or any other Traxxas compatible starters will fit with no issue's. The main difference is the exhaust outlet on the Go engine is somewhat bigger. The GO uses a spring mounted header. This one come with one that is compatible with a revo not the T maxx truck. May have some issue with that not sure. So if your planning on running the stock maxx pipes your going to have to come up with a header to fit. The carbs have some differences also. The Traxxas 3.3 carb has a much larger opening. The carb on the GO engine itself seems to be made very well. The Go engine carb is a standard slide 3 needle, with your HS needle, LS needle, Idle stop screw. Check pics for side by side comparison. Weather permitting I will get a good break in. Weather here is extremely bad here at the moment.
