tudordewolf
- Thread starter
- #101
Hmm, I not sure I understand fully what you are doing with the wheel wells, didn't even know they are called that, haha.
On all my planes they came already glued in. Does your P51 have one servo in the middle of the wing which works the retracts? Also your landing gear, is it machined aluminum like FMS planes or a springy wire?
Talking about retracts, I finally finished my Nitro to Electric conversion of Kyosho FW-190 warbird the other day. After two years in the making, I just installed the final part, which was the retracts servo. What I do not like on this model is the springy wire landing gear. I think some later models of this plane came with nice Alu machine ones. I was trying to figure out which FMS landing gear would fit the model, but there's so many out there, that for now I just gave up and decided to see how it behaves on stock first.
This plane will be able to push towards 1300W of power , it should see it fly pretty fast on 6S.
I used the FMS "Predator" 550 KV motor that is stock for their F3A Aerobatic Pattern plane.
The CG balanced out perfect with the battery pushed all the way up against the firewall.
I hope if survives the first flight, the adrenaline is too high when you take off with a plane you just put together or have done some major mods to it.
Now its back on the shelf again, until I obtain some 6S packs. Hopefully soon.
ASP and Magnum are exactly the same engines, from the same factory and manufacturer, name depended on which continent they were destined to I believe.
Seeing those prices on Ali, they are not cheap, I can usually get them for half the price here locally.
Now, about tuning ASP, which you asked me about in particular the LSN which you asked me about a few posts above.
Yesterday I ran the 4 Star 40 for the first time, and I noticed that the engine IDLE increases as the fuel tank empties. I thought OK, LSN is on the lean side, so I richened it, now when I re-fuel, its too rich, idle did go down however. Its nothing major, I could fly it like this, but still it annoyed me a little. I was happy to see the engine dry, after sealing it all up with silicone and plumbers tape (exhaust), there is a small leak still present where the carb slides onto the fuel intake pipe, I am not sure if I am explaining it correctly. There is small O ring in there, if you ever had it apart and saw one. I think I will mod this as well and add another O ring in the upper portion of the carb, as per pic. Here's a brand new 61 engine and you can see how its kind of twisted to the side, causing fuel and possibly air leak. I don't want to go down the rabbit hole and start hunting for mysterious air leaks because its not running perfect at idle. I will attribute this to engine still breaking in. I have read online they take 3 gallons to fully break in, wow, not sure if I will even get to fly this plane that long. Maybe we should just buy second hand engines, at least they will most likely be already broken in, or at least half way there, haha.
Machined aluminum landing gear. The wheels wells didn't come glued in, the film wasn't cut out for them from the wing, and the wells themselves were still in vacuum-formed sheets, I neglected to take pictures of all this, but the manual describes it well:
Like my other nitro builds, I'm bumping up the wheels to the absolute max that will fit, 85mm instead of 75mm, to maximize ground handling. It uses a center servo to operate the retracts, i'll be using this low-profile servo rated for 13kg @ 6V and only 3.6A stall current, which I'll still put on a separate BEC just in case so it doesn't brown out the receiver if the gear jams. It even has 180° rotation, perfect for retracts.
Haha, it needs to be bent backwards a little, towards the car. That's the radio antenna the car came with. Go figure!
That's one big R/C!
