tudordewolf
Been working on this one for a while, it's reaching a point where there's enough to share.
The first thing that stuck me is how much the bare fuselage looked like a ship from star wars, (specifically a naboo fighter) especially if I held up the spinner to it:
The colors, the way the tail points & especially the contours under the cockpit, which on the P-51 are to smoothly blend with the wing, are just "left on" the ship.
This one has been a lot of work. The other 2 ARF's I put together before this one were less work across both of them.
As shipped, the kit leaves gaps and lines that I've closed up with extra monokote, I feel like a small piece of extra pieces of the colors used would be a smart addition to the kits, but oh well, they're only ~$20 for a lifetime supply of patch-pieces in the form of a whole roll.
I went through several choices for the landing gear retract servo before my first choice even arrived, I settled on an SPT 4420LV and it is perfect in that role. Optimized for standard voltages so it offers 20kg*cm of torque at 6.0V, & low profile, as a normal height servo wouldn't fit:
At 125% endpoints on the remote, it has 120 degrees of travel. Using the right sized servo arms though, this is still plenty to lock the landing gear at both ends of its travel- video to follow soon.
For the rest of the plane, I'm using DS-Power "S011M" servos which advertise ~4.3kg*cm at 6V, perfect for replacing old standard servos with something a bit smaller and lighter, at 15x35mm footprint instead of 20x40, and they fit a standard 25T horn. These have been my go-to for my nitro planes, and they're a steal at under $10 a pop even for the metal geared version.
Of course, all the plane's servo trays are cut to 33x16mm, a size very few brands even cater to. I thought I'd finally found them in the 3.5kg-rated "M0200" servos, which had the right footprint, but a miniature servo spline, so I'm only using 1 of those for the throttle, to at least use up some of 5 I bought thinking I'd use them throughout. The Sonic from Phoenix model also assumes this unusual servo size, so I've used 2 of them so far, they work well enough. It's just a little woodworking to adapt them, but that's extra steps that turn into extra days.
