Frustration, or: A Tale of Two Slashes...
clm77
Hello, all. Not long ago, I decided to return to RC racing, for a multitude of reasons. Sensibly, I got on FB marketplace and located a truly bitchin' buggy that's pretty much ready to rip with very nice electronics and the whole nine yards. Then I went to my nearest racetrack and observed the action. The reality of how small a chance I would have of shaking off the rust without destroying a bunch of nice parts, while trying to get a 2wd buggy powered by a 6.5t motor around the track smacked me square in the face. With a quickness. I needed a plan b...
So I thought about last time I raced a little. I decided I wanted a short course truck. The last one I had was an HPI Blitz, the one with the cool white plastics. I started looking for a kit, and found... not much out there. I kinda wanted to keep it on the inexpensive side. The Slash "kit" was there, gross electronics and all, for a cool hundo less than an AE 6.4sct kit. I have been trying on a personal level (bigger picture, as a human) to not take everything so seriously, and just relax and have fun. So, I decided to try a Slash. Now, I have known for some time about the nature of the Slash. Last time I was racing, when I saw a Slash on the track, I would assume that shortly I would witness it barrel-rolling into someone else's rig, or mine, which would break, then the (usually pimply adolescent driven) Slash would make haste toward the next corner and repeat the process. So I knew that I had a challenge before me. But, we can turn it into plucky but competitive underdog, can't we?
I ordered the "kit", and a few upgrades. Then a "few" upgrades turned into a LOT of upgrades. At some point, I realized that I would have been money ahead if I would have just bought the AE kit. But the plucky underdog appeal guided me. Then the packages began to arrive, and I started assembling the thing. That's when the frustration really began. Not because of assembling it, I enjoy that perhaps more than driving one. The instructions are decent, clear, and logically laid out & ordered. No, the frustration came about because all the previously held beliefs about Traxxas "kits" immediately began to be proven true, before my eyes & by my own hand. The plastic is of poor quality and doesn't hold any measure of torque, nor is the line between "snug" and "uh-oh" consistent or readily discernible.
Worse yet, the upgrades. I stayed away from the generic stuff, common sense. First order of business was an lcg chassis, obviously. No problem there. The upgrade box got so full, I soon realized that I had two Slashes worth of parts, if only I were to buy a couple more things. So I did. Then, upon completing the major assembly of the "stock-ish" lcg Slash, I started assembly of the upgrade-laden blingwagon. Man, really? RPM arms don't fit on the Proline transmission (integral arm mounts)? Ok, take the stocker apart a little, test fit on the OEM transmission... fit ok there. Grr. Dremel time. Took a little bit of material off the forward end of the arm mounts, carefully. Ok, fit is acceptable now. What's the rattle? Oh, the slipper clutch assembly is laying in the dust cover like candy in a piñata. Grr. The STRC front bulkhead and shock towers are quite nice, no complaints there. The Traxxas bellcrank assembly is also a decent bit of kit. The nyloc equipped hinge pins, not so much. Thread the nut on deeply enough to meaningfully engage said nyloc, the arms bind. Grr. The Traxxas brand-name caster blocks & steering hubs? Pretty sloppy, honestly. I think I had a clapped-out gold-tub rc10 back in the day that was tighter. The Traxxas brand-name turnbuckle kit? Two-thirds fit properly, had to go back to the well & order a pair of rear camber links because the provided units are at least 10mm too long. Grr. Honestly, the stocker front end feels better in the hand. Grr. Worst of all, the MIP CVD kit was shipped without the stub axles or instructions. To be fair, I have reached out to MIP & they offered to comp me a pair of stubs, but still... Grr.
This evening, I went to install the Traxxas GTR shocks. Which were clearly stated to be compatible with the 2wd Slash. The lantern-shaped insert in the lower mounting point on the shock, the correct terminology is escaping me at the moment, sorry. It doesn't fit in the RPM arm or the OEM. GRRR.
TLDR; I should have bought the Associated 6.4sct kit. I don't even intend to use any of the electronics that came in the box, 16awg motor wires, seriously? Why oh why have I done this to myself? Light me up, everyone. Might as well have some entertainment outta this misguided adventure....
I’ve seen a LOT of people be successful at bigtime fun with the Slash.. Unfortunately it seems they’re very good at doing that when they are pretty dang close to box stock.. 😅
Only now do I see that this is the way. Shoulda done lcg & good tires & called it good. Or just bought the AE kit...
Upgrade what ya can without demolishing the setup, and get out there and hone your skills. Then pick up that 4wd Associated-or better yet; get someone to let ya wheel their 1/8 buggy or truggy for a few laps.. You’ll be hooked.. There’s not a more durable, or capable platform imo, and they’re super forgiving. Success rate, and fun level are HIGH.. 😉 Regardless, you’ll have a ton of fun with the slash, and there’s never a shortage of people for the class. 🍻🤘
The thing that annoys me the most about the Traxxas's Slash "kit"... it's just an unassembled RTR. Sorry.
Exactly. It's a kit that would be great for teaching a kid to build an RC car, minus the soldering aspect. But other than that, it is just a bottom of the barrell Traxxas.
We have all been there. Start out with something we think we can build cheap, then end up with way more money wrapped up than we intended.
I would keep a watchful eye on @Littlemotor here. He occasionally posts some killer deals on used Tekno's. If you want a quality RC, that's going to be the best bang for the buck. They are super nice kits, with aerospace quality components. I machined stuff for IndyCar, NASCAR, and NASA. The Tekno stuff is insanely good.
Oh, and great read there on your journey 😉
Well, thanks for indulging me & listening to my late-night whining lol... I'll figure it out. Probably cobble together a rig outta the parts I don't care for the fit of & sell it on. Unfortunately, there isn't any spec-Slash racing near me (that I'm aware of), and the 1/8 track is a good couple of hours away. The only track within a reasonable distance is an indoor clay situation, and doesn't seem to have any SCT-specific classes even. I truly wish 1/8 was an option! Always looking at them on marketplace. Anyways, have a good one fellas...
The good news is, you've got a fun truck you can race, bash and have fun with.
I don't typically do a lot of back yard bashing with a track racer... too much $ invested to bash it on jumps and running into trees, rocks...
I bought a couple bashers for just this reason.
You have a capable and fun truck at least.
I tried to build up a DeeRC 200e buggy when I returned to RC. I wanted something different and fun. I built it all out and came to find out that unless I figure out a few giant flaws in the design, it would never be what I was hoping to build.
Its in a box in parts upstairs somewhere.
Lost cause, lesson learned. 🤷‍♀️🤣
MIP has been around forever! I'm glad you reached out to them and got the issue resolved.
They are good folks to deal with.
Go have fun with your Slash! Plenty of ppl build up their bashers and back yard racers too. Nothing wrong with having an edge. 😎
Plan out your next build with a race chassis and you'll be happy on the track too. 👍
I believe @DavidB1126 built his Slash to the point that it no longer qualifies as a 'stock Slash'.
Thats how a lot of Slash class races are run... as 'stock' trucks.
You know what you need to buy to get on a track now at least... get shopping and go racing!!!
Tonight's installment of frustration... above, I noted that a turnbuckle set that I ordered which was clearly stated to be appropriate for the 2wd Slash had rear camber links which were 10mm too long. I ordered the 39mm links a la carte, because my bad, obviously. Received today, I kid you not, straight outta the Amazon envelope:
So, now, whining aside, does anyone have a suggestion or part number for a part which might fit the GTR shocks to the control arms? My initial thought is to use a cutoff wheel on the dremel to cut the hollow ball-end down to fit, but that seems kinda shady... I would strongly prefer a solution involving a legitimate part. Any tips much appreciated.
