foam inserts for proline 2.8 road rage tires?
Thanks for the reply.
Do you think i can just buy 2 and use 2 of the white foam inserts that came with the tires as long as i keep them together? (ex white in front and blue in rear)
the description says for the mashers, trenchers, and sand paws?
Yes, that should be fine.
I saw that but I would think a 2.8 foam would fit any 2.8 tire. I'm guessing they may have designed these foams with those 3 tires in mind specifically but I'm pretty sure they will work with any 2.8 tire. You could also drop a quick line to proline and ask them to verify.
