- Northeastern NY
- Crawling
- Scale Builder
- Flying
- Boating
My Terranaut radio (Flysky FS-MG6A-BS) doesn't stay bound overnight. I have to try several times to get it to re-bind, then it says bound for the rest of the day.
For example, I ran the Terranaut early last evening and when I turned on the Tx a few hours later, the green light on the left (the "G-LED") stayed steadily lit and everything functioned as expected when I powered up the Terranaut's Rx. It will function normally like this for a few hours.
But when I turned on the Tx this morning, the G-LED green light on the Tx display is flashing green and the Tx beeps continuously. The G-LED green light will stay flashing even after I power up the Terranaut's Rx. The Terranaut will respond to the Tx normally but the continuous beeping from the Tx makes it unpleasant to use. It takes repeated attempts and cycling the Tx on and off to get it to rebind.
I'm using fresh Energizer "Ultimate Lithium" AAs in the Tx and I'm turning the Tx and Rx on and off in the normal sequence.
Any ideas? I'm hoping I'm missing something obvious and having some kind of brain fart...
