First rc Slash bl2s update and my journey to monster wide slash
cocoune
RCTalk Racer
Hey guys,
I bought my first rc maybe a month ago, a slash bl2s. I said ill do an update so there it is. I will also document my journey into upgrading to a monster wide slash.
Its alot of fun. I'm good with 2 s now and one battery only. Its a genz bashing 5200 mah 35 c. Changing the motor and esc will probably be one of the last upgrades i do.
I mostly run on dirt, rocks, grass and try to go easy on asphalt. Did some speed runs here and there.
What i changed and broke so far is the front shock tower (rpm), caster blocks (rpm), pins, springs, front skid plates, bearings, i vented the tires (after i fiddlesticked the foam in rear tho), i bought tools and front rpm wider arms. I also found a sweet spot for counter weight (just in front of rear axle). I dont have it right now but i plan to put it back. I have pretty stiff springs in the back and soft in the front with no preload. The shocks are close to the wheel in front and close to the chassis in the rear. I put a 90 spure gear instead of stock 83 just because.. i already have 14 pinion for bigger wheels but ill buy a temp gun just to make sure i dont break electronics.
I want to buy 40 shock oil to see what it does and try longer shocks for more travel and ride height. Maybe upgrading the servo but i need your help for this one lol
What I'm doing right now is changing the arms so its wider. Ill need to trim the body and find a way to rise it but keep the clipless system because i want to buy badlands 2.8 tires (the narrower ones). I will put dry wall tape and shoogoo to protect the body. Its already beat up.
Ill keep updatiing :p thanks
Man, I really want to convert over to the clipless system on my slash. I need to take that thing out and fix it up, I love the platform. I can run downstairs and see what Savox servo I'm running in my 4x4 vxl, it's not the fastest on the market but Savox makes a good product. If you want more suspension travel you can run rears in the front - I'm not aware of any "long travel" setups that are super easy plug and plays for these things.
If you're feeling like spending a pretty penny you could always do the Proline Powerstrokes - it's a bit overkill but they're pretty sick.
I think its pretty easy and cheap to convert it with clipless. Clipless is all i know but I'm sold. Its super cool and user friendly. Id say go for it. I have to find a way to rise it but I'm pretty sure traaxas will sell a clipless kit for that soon.
I dont see any big problem with the servo now but it would be fun if its a little quicker and stronger, ill check savox. Anyway i found that driving style is really important. Some set up has bigger roll but you just neet to adjust. And to be honest i rolled a few times (of course) and most of the time its really smooths and doesn't seem to have the potential of breaking something. I prefer that over hit a curb lol
I think rear shocks in front is a good idea and maybe i could check the 1/8 traaxas for the rear. I'm planning to stay plastic right now. I dont really see how pricier shocks would upgrade performances and i want to invest that money in other things. Thats why i chosed to trim the body instead of buying a new one and i like the protection that short course body gives me.
My servo broke from just driving on gravel roads and I got a stone stuck under the chassis and servo arm - caused the servo gears to strip out.
As far as the stock shocks I would just get the TiN shafts, a set of 4 rears. A couple rear springs, and then order the aluminum shock caps and you'd be pretty set. I have a small fortune in the amount of stock shock struts I've broken and replaced. This is the best bang for your buck in the reliability department.
And the clipless swap is easy and cheap, but idk I want to run other bodies than the traxxas stuff for my slash it's really the only reason I haven't done it. Plus I've kind of become obsessed with Nitro. I'm half tempted to fix mine up or sell it for parts and replace it with a nitro slash.
Traxxas 2656T for the TiN shock shafts
Traxxas 3767 For Aluminum Shock Caps
Springs go with whatever floats your boat. If you're gonna be jumping a lot you might want to jump up in Shock oil weight. I run 40 in my slash but I'd still like a bit more, the 4x4 is also a fair bit heavier though.
Hope that i dont break my servo lol las time i tought i fiddlesticked something bad because rear right was doing a big grinding sound. Turns out It was a rock stuck in the arm and the driveshaft was rubbing.
The hobbyshop owner told me the shocks can strip one time but more than that its done. Allu shock caps are cheap too. And thanks ill consider shock shaft if i stay stock.
I already have 3 differents springs. I dont jump alot. I like pump tracks but i try to land clean. I feel that the suspension go down fast but i didnt find the right spot with the spring rates and preload yet. I like to add weight too so 40 oil may be better. But like the hobbyshop owner said if i dont like it i can't put the 30 back. I need to keep that in mine.
Yea maybe if you want to put othe bodies its better to stay with clips. I like the screw desing tho
Ok i just put the wide front arms. I have rustler longer toe and camber links. I had to adjust it a bit but it was easy. Pretty sure i need stiffer springs because of the levrage but i wont need to trim the body as much as i thought.
I ran it for a few mins in my yard without the body. I feel like longer arms upgraded drastically the offroad capabilities.
I want to do the same in the rear but it looks perfect like this.
Oops i have positive camber in the rear need to correct that
Update : i lifted the body with pvc pipes and 30 mm screws. Its super easy and work great. Looks solid. Its not perfect but i wanted to ride lol.
For now its way to high but i think it would be perfect with badland 2.8. Tonight i will put it down a bit.
I did a pack on it and it runs amazing. The way the suspension work with wider arms is really cool. Didnt find the sweet spot yet but its so much fun.
Oh and i understood something about servo speed vs sensitivity. I heard alot about the not so good traaxas servo. Maybe i dont know. I'm a noob and its seems fine to me. Its a bit slow BUT, i feel the sensitivity is good. I dont feel any delay between the radio and servo.
View attachment 190806View attachment 190807View attachment 190808View attachment 190809
View attachment 191078View attachment 191079View attachment 191080View attachment 191081View attachment 191082View attachment 191083
Hey !!
I put the rear wide arm the last weekend. The only downside is that i used to put the shocks near the chassis and those holes dont exist on the rpm arm. But thats not a big deal.
I really want to have more travel tho. The first thing in mind is longer shocks. In the front i need to make sure the toe link does not rub on the skid plate and on the back i need to watch to not strech the driveshaft to much. Its already streched because of the wide stance. Maybe i can put rear slash shocks in front and try to lower the mounting on the rear shock tower by making new holes or buying another tower.
So far the handling is nice. The longer arms works really well. I'm close to a sweet spot with the suspension and have more understanding. I feel that whatever my suspension settings, balqnce between the rear and the front is the key. Ill try to play with pistons and maybe oil weight.
Next thing after the ride height will be the bigger tires but I'm scare ill want 3s fast because of the speed lol
I can anwser more detailed questions about the upgrades done.
Have a good day !
1000002538-jpg.191358
I finally put badlands 2.8 tires. For now, i have the longer adapter in the front but ill do the rear too.
I have 2 problems tho. The rear wheels are a bit on the threaded part of the shaft holding it. And the hole of the wheels are a bit too big so its wably. I can try to tight the bolt when the wheels are completly in place but its hard and not optimal. There is the same problem in front but the wheels are straight. Rocks get stuck in the wheels too but I'm fine with it. Lol
Its alot of fun ! I drove once without the body (I need to trim it ). I really like the handling. I feel the grip. Its pretty much "impossible" to flip it. My gearing is 14/90. I feel i can go higher. Stock gearing is 21/83. But i like the torque ! It just go trought things.
Those tires are a game changer. Thats the truck i wanted and the fit with the wider arms is amazing. I'm on 2s so i have room for upgrades.
Hey a few things happend since the last time I posted.
Yesturday i bought big bores for the rear. Honestly i had no particular reason to do that. My lhs answered alot of my question, i wanted some parts that they dont had in stock and i didnt have the parts number. I wanted to buy something and i already had a bent shaft so i was like why not.
The reason i didnt bought tue Gtrs is because I'm pretty sure it would rub on the camber link. Even the big bores did. I had to put the ultra ball joint on the a arm and a little shim on the shocktower mount.
I know traxxas but I'm a bit disappointed. I knew before buying but seriously ? 2mm smaller than the ultra ? Why ? I know its not a big deal but its annoying. I already had hr progressive springs (red,silver,black) and its loose on the big bore. This is a big brand move. Smaller prelods clip etx. I have rear linear traxxas springs and the finishing on the ends is not great unlike the hr. The spring curves when compress. I sanded it, its better but still...
But now that i have allucap and stronger shocks i might go harder on it :)
I tried rear ultra shocks in front but its not working unless i drill new mounting holes. Maybe ill try that.
I put metal sheet on the rear skid plate to simulate the rpm skid plate. It worked well and less things get stuck.
Like you see in pictures i have funky prelods. I tried it yesterday and liked it. It looks wierd but.. lol
Oh and i totally ahredded the built in fan in the motor xd i was unaware but a rock got stuck and broke all the teeth. Its also stripped from the shaft. It will turn but not all the time.
I run 16/83 and didnt have heat issues. Ill try to contact traxxas for the fan. I feel it was normal use and its a bit odd that i broke that.
I also stopped going in 1" gravel parking lots. Rocks allways get stuck in the wheels and I'm too afraid of breaking something because of that.
Next upgrade will be a new servo. Now that i have the 2.8 i feel the needs.
I want to buy a amazone servo and can't decide between 20kg or 35kg. Fast servo would be nice too. After that it would be the 3s esc motor combo. Its gonna be the the firma 85a that my lhs sells or an hobbywing like the 10bl120 and quickrun. But I'm not sure about what spec to get. Maybe they can help me.
So thats it. Ill try the bigbores in one hour. I'm pretty its going to be the same haha but it is what it is :)
Hey guys,
Ill keep updatiing :p thanksView attachment 190779View attachment 190780View attachment 190781View attachment 190782View attachment 190783
Why do you wire tie it? I'm just trying to learn.
I think he is asking about the bolts you have zip tied to it in the pics above.
Oh yea it makes sense
Keep in mine i just started. I'm a noob.
I put the bolt like 1 week after i bought the car. All the weight is in the front and i tried to fine a way to make the front more planted. I found that the under the esc was the sweet spot. It was overkill but honestly it worked really well. I removed it because i started to mess with the suspension tunning and wanted the stock vehicule. I might try that again but since i put bigger tires on it I'm worried about motor and esc temperature.
And i dont recommend to do it like i did. I wanted something fast but eventually it will break the skid plate. I tried it in front and thats what happend. I knew it but didnt want to spend the time to do it right. And like i said that much weight is kind of overkill. But it worked xd
Interesting springs for sure. But hey, if they do what you want, awesome. For rough/rutted track, I always added weight to my 2wd SCTs. About 4oz. most years to be exact... plus the ballast weight that was included in later versions of the platform. It just handled so much better.
