First 1/8 race of my Career comming up!
heres a link to the insite of a carb
The throttle stop screw or idle-speed screw (same thing) determines how far the carb barrel will be able to close when the servo is in the neutral position. Typically you set the servo/throttle linkage so that the carb will go from fully open when the trigger is fully pressed to fully closed when the trigger is in neutral. Then you would adjust the idle-stop/speed screw so that there is a 1-2 mm gap when the servo is in the neutral position. You might need to readjust the spring collars on the throttle linkage to force the throttle arm against the idle speed screw.
Tip#1: If you completely mess up the carb setting and you want to go back to the factory recommended needle setting then you must have the carb fully (Yes I mean fully closed) before you can set the low-speed needle to whatever turns the engine manufacturer suggests. Before you close the carb fully back the low-speed needle a bit to make sure you wont put un-needed stress on the needle seat.
Tip#2: There should be no speed change whatsoever when the car is in idle and when you hit the brakes. If the engine's RPM drop either your linkage isn't set right or the idle-speed screw is set too loose. Tighten clockwise until the carb barrel doesn't move when you go from neutral to full brakes.
Tip#3: Some RTR kits have servo horns that are too small. There is not enough servo throw to open the carb barrel, if you use servo trim to be able to open the carb fully, then when you go to neutral the carb doesn't close enough. To compensate for this the novice engine tuner opens up the low speed needle to drop the engine RPM so the car will stay still when at idle... The drawbacks of correcting the linkage problem with the mixture control is that now the low-speed is too rich and the car won't idle for more than a couple of seconds before the engine sputters and dies.
To fix this problem you need to get an after market servo horn that is larger yet still fits your particular servo brand. Now you can go from fully open to fully closed, without using trim. Now you wont have to compromise the carb settings because of lack of servo throw.
Low-Speed Needle:
Thanks to http://www.nitrorc.com/ for saving me some typing
mikeburgin said:
. . . You might need to readjust the spring collars on the throttle linkage to force the throttle arm against the idle speed screw. . .
Plaid, this is what I was referring to. I know better, but I learned the hard way when I first got my car, by having it die a couple times, and scratching my head for a while wondering why before I figured it out.
Dude really first race. GOOD LUCK ITS GONNA BE AWSOME. I HAVE NEVER RACED EITHER. Cause my car is broken. But I'm getting a 1/8th scale buggy. I can't wait. I Think you'll do fine just keep it consistent around the corners and let er rip on the strait. And u'll be fine. GOOD LUCK ONCE AGAIN!!! :cheers:
Thanks dude,
I am really looking forward to it. The guy at my LHS track likes to have fun with the newbie racers... so I can hear him now.... "hear comes Tom still in last place.... but his car is in one piece!" I am just excited to get out there and get muddy. I have an XTerm Pro, not a top of the line, but I just want to get out there and shut those guys up who were making fun of it. They all drive Kyoshos and Mugen, and Ofnas..... Oh well so my buggy didn't cost a grand.... I like it.
Alright thanks guys. Now i have to wait... Ordered wrong charger for my s-box batteries. Now i have to send it in and Wait till they send me the correct one. THe bad news is my first race was suppose to be sunday! So now i have to use a pull-start on race day. Sounds good guys ill lean my hsn and let ya know how it goes. Thanks guys.
Here is something that works for me every time.
Send the girlfriend off to a day at the Spa.
Let her get pampered for the day, you look like a hero, and take the time you need to do the break in right.
Hey guys,
First race is now in the history books... Man was that cool. I have never seen so many classes of RC's racing in one venue before. You had the stock, the modded, the pretty, the ugly, Electric, Nirtro, but no gas. The only two classes I can run are MT, and 1/8 scale buggys. It was just so cool. The class with the most entries were the Electric 2WD Stadiums, and Nitro 2WD stadiums. Those two classes were real competitive. Fun to watch too. Those electrics were quiet as hell. There must have been five or six on the track and you could barely hear them, unlike the nitros which with 3 on the track you couldn't hear yourself think. I found out alot about how to turn marshall, and what the rules of etiquet were. Made some friends, and found out the 1/8 scale trucks do not handle real well. Also found out that the Revo is freakin awesome! I found out so much great info... hard to keep track. One thing I found kind of interesting though, is that stiff springs and stiff shock oil works the best. Anywho, not to keep rambling, I just had a blast. Can't wait, in two weeks point racing starts... this weekend was just a test and tune in a race format.
Not a bad idea.... In fact I may just try that... thanks Ratzo!
Tom
Plaidfish said:
how did you do?
Dude, lets just say I have some work to do... Had fun which was the important part... having a hard time with the table top and judging how fast I need to go to negotiate the triples, doubles, and all that. Just could not get a rythme going. So pretty much just need to get the feel for the whole track. I got out drove by an 8 year old girl in a XXX T. Man she was fast!
OOO man that had to hurt.....I get out driven by this 10 year old at my track....he does have a sick 777...but he is a very good driver still.....I have to really be on point to clear the triple...he pops it like it's nothing everytime....oh well...I'm getting a better engine soon...probably a P5 long stroke.....w/ a 063 pipe....maybe a different pipe but I know I'm ready for a mill that has a lot more ass in it now....I'm driving the hell out of my RGs and doing real well keeping up w/ people.....w/ my fantom I was just walking all over people and now I miss that.....
You know it didn't bother me too much. I see her and her father practicing all the time, so I know she gets it honest. I just have to practice. The fiance is going to be out of town most of all next week so I figure I will just throw my stuff in the truck and take a ride. I still can't get that RG firing right yet still cuts out fairly frequently on decel... but the temps are still around 200. Still have some work to do. Hey man you daughters at the right age.. maybe take her out and teach her to outdrive those trash talkers.... :)
she's on Mini-T training right now....I let her try my buggy in a field and she almost killed people.....still not savvy w/ the concepts of engines and not going WOT all the time yet...we even built a OS 15 a few months ago....she did most of it too......I just had to help w/ lining things up to fit together.......
Wow dang that would have sucked. HOPEFULLY she gets better at driving and she wont almost kill someone again. What kinda stuff does she have on her mini-t ? Is it preaty good or is it just stock to train on? :)
Aluminum Losi shocks...orion batt (going dead)...hitec servo.....and a Baja motor.....orion pinion gear...Ti turnbuckles, balls and RPM ball cups.....oh yeah crowd pleaser body.....she's getting good at it
