Think 17mm is the standard.
It's kind of funny that is the exact pipe I have, but with the side exhaust manifold.
But what i was meaning by it is retained by a spring is, if you look at the hyper 7, it has a silicone coupler that holds the pipe to the manifold. Then the manifold is held on by a spring to the engine.
Losi uses 3 springs and an exhaust gasket to hold the manifold to the pipe, while also using a spring to hold the manifold to the engine block. I do agree the hyper 7 one is a bit long, but I was able to get a longer exhaust hanger wire to locate the muffler/pipe further out. I did have to trim my body to do this though. Might have to swap my lst pipe onto my mgt. I know it was a popular mod back in the day to wake up the 4.6 AE engine. Coupled with the fact the combo used to be quite cheap.
