Bellr77
First off thanks for looking even if you can't help I appreciate the fact that you tried. My current project is I'm trying to out a XTM .18 engine in my spare truck which is a Nitro Sport, I've hit a bit of a brick wall while trying to get the clutch assembly from the Pro.15 engine to work, the shaft is longer than that of the Pro .15 which uses a bull nose nut that has a grove for a clip at the end., the gear sits on the bull nose. Unfortunatly the bull nose nut bottoms out before getting close enough to the engine, I tried a clutch nut from a TRX 2.5 thinking this would solve my problem but the shaft isnt long enough to stick through the gear (clutch housing?). I'm down to wear I'm out of ideas and will either have to sell the engine or try to cut down the shaft neither of which is exactly a very appealing option. Can anyone give me a better option than the ones I have???
