CessnaDriver
Ok, I am finally done with the build of my Mugen MBX5 ProSpec. The body is out to be painted and I am ready to break the Novarossi P5X in.
Should I put something in the glowplug hole to loosen it up a little?
When first running the engine, you have to crank it until fuel gets into the carberator.
Isn't that all metal on metal contact? Or do new engines come with some kind of lubrication in them from the factory?
Those Novarossi motors are tight, I can't even hand crack it from the flywheel and that's even with the glow plug out of it and no compression.
I sure hope the starter motor can turn it over.
