Assuming this is a Traxxas 2wd
Just to clarify, a generic Amazon aluminum case with ProLine internals? Should be able to fit if the diff outdrive and bearings are the same size to fit the aluminum case one.
But which aluminum case are you using? Generic one off of Amazon or something like hot racing?
@luke66 uses a aluminum case in his mm rustler and
@WickedFog uses a aluminum case in his drag slash.
I use a 272R in my slash and a regular 272 in my rustle
I use a 272R in my slash and a regular 272 in my rustler.
My pro line trans and case is different than the Traxxas 272 I try to replacement case yesterday and did not fit it all
