Guys, In the past I have had problems with wheels coming off axals when bashing or just running around. They have been tightend down to a tight fit prior to start. Do I just make it a habit to check and retighten every so often or does anyone use (Blue) loctite on the lock nuts or axel thread, that the lock nut s mounted to, to keep tire mounted to axal. And if I do use loctite, Will over time, Will that breakdown axal in anyway. This is part of a thread SD had out...
All screws wear out eventually, especially ones that you remove regularly and also those that have loctitite on them. They are a disposable item.
__________________
So..I am curious if this would be good practice with the Loctite in that area, or just make it a habit of checking and tightning every so often.
__________________
