After market parts are becoming scarce. Ebay and Asiatees are about the only 2 decent sources for aftermarket. ebay is a great source for stock parts as well.Ok cool. I think I'm gonna order up some blue aluminum shock bodies. What website do you guys use to order your lst2 or xxl parts stock and aftermarket? I've found that overdriverc.com, amainhobbies and rcboca has some good stuff. Are there any others?
The only parts that arent compatible between lst2 and xxl are:
center drive shafts
Chassis rails
Center chassis plate (upper and lower plates are the same)
Body
The only other difference I can think of but are still compatible.
The went from using the Dynamite Mach 427 to the Losi 454
No high/low gear selector on the transmission
went from FM TX/RX to 2.4GHZ
Added telemetry (I dont run the telemetry on either of my kits but it looks like it would be compatible)
changed from aluminum body shocks to plastic body
Thats all I can think of atm.
Good score! If they aren't already, I would suggest upgrading to the lst2 a-arms and hub carriers. They are much stronger and eliminate the rear toe links.
Sent from my XT907
