do i reallly need to wait at least 10hours?!
roozy
need to wait at least 10hours to charge igniter?!
for the new glow plug igniter to charge?:ahem:
unless you have a quick charger that will do a single cell, yes you will have to wait. You want to be sure that nicd batteries get a full charge, especially the first time, as they will develope a memory.
You could always get a D cell ignitor for those times when you want to run but don't want to wait for the charge. It is also good to have one in case your rechargeable fails.
Be happy ur is 10 hours. I had to charge mine for 12-15 hours. Before the first use.
If you want to spend about $50 or more you can buy a peak charger with single cell capability. It will still take a few hours to cycle the D cell battery though. Not 12 hours but a fair amount of time, you don't want to charge it too quickly or you will risk severly decreasing the battery life or burning it up.
OR....you can just do what many of us here have done..... Buy the Hobbico battery and a glow clip (the kind that is used with a starterbox) from TowerHobbies.com or your LHS. I modifued my Glow Clip and added Alligator Clips that you can buy at RadioShack for like .50 cents
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXL368&P=7
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNS92&P=7
Everyone who has one says they will last through an entire season...no recharging needed. For $15 you can't beat it.
Heres a pic.
Technique
Heres an example:
Say your battery is rated at 1800mAh
Say your charger is rated at 200 mA
this means it would take 9 hours to fully charge this battery from complete discharge.
So check the battery and charger output and just divide the battery/charger output... thats how long you should charge for.
Hope this helps
