Hi there -
My mill consistantly runs pretty hot so I will try and give you as much info as I can so that you can tell me whether I most likely have an airleak, or that I'm just being paranoid...
Outside temp approx 52 Deg F
An STS .28 engine with factory shims
15% Nitro Fuel
Running on a dirt RC track which is quite tight and small (so I'm hardly WOT at all except on the small straight).
My running temp maxes out around 268 deg F
Lots of smoke under throttle.
Gear ratio - 16t clutchbell, ,44tooth spur gear.
Car: Kyosho Inferno mp7.5 buggy
I've done my best to seal the backplate with high temp RTV and also the carb, and have new fuel hosing. My tank passed the underwater 'bubble' test with no leaks.
I have it running very rich - lots of smoke and it even gurgles quite a bit off the line. It seems to get quite a lot cooler (230-40) when it moves and gets airflow, but idling the temp gets hot again. However if I richen the LSN, it stalls under throttle.
I'm thinking about taking it to a hobby store and seeing if they can do a better job of finding a leak than I have unless you guys think I do not need to bother??
Thanks
Chris
15% Nitro Fuel
Thanks
Chris
