Dbx 2.0 problem starting..
Salw87
Preston, uk
Hiya I've been having trouble starting my kyosho dbx 2.0. If I remove the air filter and blow fuel straight into the carb, it will start first time. But it will cut out after 5seconds once that bit of fuel has been used.. Like its not sucking its own fuel from the tank... I've taken off the carb and cleaned it with air compressed and it made no difference.. Anyone else having this problem.. Help please x
I've had the fuel inlet nipple get clogged up before and also if your engine is worn you may not have enough compression and this will also cause this same issue. So first thing make sure you have good pinch. Then inspect all seals and gaskets for leaks. May even want to reseal the engine itself.
