Your fine.
As long as you only scratched the top and not the sides or the inside of the sleeve or poked a hole in the piston itself, you should be fine for quite some time.
I put a good gouge in the side of my piston about 5 gallons ago. I couldn't get the flywheel nut loose. I didn't know about hydrolocking the piston with ARO, all I knew was the ziptie trick where you stick the head of a ziptie in the exhaust port with the piston down to lock it. It was so tight that it was shearing off the ziptie. So, I took a small pair of pliers I have that have plastic coated handles and stuck the handle in there. Well, I got the nut loose, but it cut through the plastic of the handle and put a gouge in the side of the top of the piston... the gouge wore off eventually and I just recently got the piston/sleeve re-pinched.
Like I said, I did the gouge and used the engine for another 4 or 5 gallons getting a total of 9 gallons through the engine before I got it re-pinched.
