Clutch Bell Help?
leadfoot567
I have a XTM Monster MT. I'm trying to seperate the 2 clutch bell gears from the clutch bell housing. I need to replace just the clutch bell housing. The gears are fine. But I've tried to unscrew the 2 gears that are threaded onto the clutch bell, but no matter how hard I try they don't break loose. I'm not sure if their "left-hand threds" or "right-hand threds" I don't want to buy both the clutch bell housing, and the 2 clutch bell pinion gears. Please help. Also can someone please suggest a good brand for some good quality clutch bell bearings. I've enclosed some attachement picture links to help describe my problem.
Thanks...:(
I had that on my Gv couldn't get them off for nothing . I just drenched them in wd-40 and let em soak for half hour then they broke loose . Don't work for every case but worth a try bud .
Thanks. I soaked it in motor oil for 1 hour. It finally broke loose. Thanks for the tip jacknife.
