As a SC10 pro4 owner, I am shocked to see the exposed driveshaft on the Traxxas slash and related trucks. Is there a way to prevent crap from entering there??
Some SCTs chassis allow stuff to fly out better. I just let 'er rip. Go faster. Turn sharper. Jump higher. Roll more.. true story.As a SC10 pro4 owner, I am shocked to see the exposed driveshaft on the Traxxas slash and related trucks. Is there a way to prevent crap from entering there??
I am shocked to see an SC10 owner buy a Slash in the first place!As a SC10 pro4 owner, I am shocked to see the exposed driveshaft on the Traxxas slash and related trucks. Is there a way to prevent crap from entering there??
What's next... a Kyosho? The horror!I am shocked to see an SC10 owner buy a Slash in the first place!![]()
I had to have a Raptor R...basically a slashI am shocked to see an SC10 owner buy a Slash in the first place!![]()
I will probably do something with a brass tube and some O-rings...If you're talking about the center drive shaft tunnel... there's not an easy way, you'd have to build a shield between tunnel and diff.
no, main drive shaftEh? You mean the telescoping plastic shafts? It's fine. Send it.
Aluminum would be lighter if you can find it.this could be interesting..... https://www.scalebuildersguild.com/forum/threads/slash-4x4-driveshaft-tube-mod.14802/
Indeed, that is great ingenuity going on. Having a chassis that won't flex will be needed. Yes, no?this could be interesting..... https://www.scalebuildersguild.com/forum/threads/slash-4x4-driveshaft-tube-mod.14802/
I plan on not beating this truck very much...just tearing around on pavement and hard packed dirt.Indeed, that is great ingenuity going on. Having a chassis that won't flex will be needed. Yes, no?
If that's your plan then I would keep it simple and just go with a chassis cover. Both the lexan and mesh covers work equally well. I use the lexan covers on my Slashes because they're visible with the body on and mesh covers for everything else.I plan on not beating this truck very much...just tearing around on pavement and hard packed dirt.
doing a net... cooler fo-shoI've never had a problem with dirt being stuffed in the forward drive shaft hole. I don't see it being an issue. Chassis covers retain a lot of heat, for your first few runs I would recommend keeping track of your motor temps.
