on a safety note: the nitro fuel you run in the engine is mostly methanol. cause of that if it gets on fire you can use water to put it out. so carry some in a bottle , be sure to mark it so you dont put it in the fuel tank.
Can you use denatured alcohol to clean my trucks?
Wow . . . . :\
Or an even better idea . . . . kids, rather than using comparatively expensive and dangerous methanol to clean your vehicle (dangerous because it burns clear – you will see your clothes melt and not see the flames burning you! :whhooo . . . instead of carrying around a bottle of water to reduce the risk of being melted and horribly scarred by an invisiable fire, add some regular, everyday, common household, non-combustible dishwashing detergent to the bottle of water, and spray that on your vehicle to clean it.
When I was a Volunteer fire fighter, that's what we did in our tanker. The dish soap acts as a wetting agent to help break down the water's surface tension. It does work so do it.
