- Oklahoma City, Oklahoma
- Racing
- Thread starter
- #21
I just used a pack of these shims here Arrma 12x15x0.2 Ara709052 all 4 in the front and i just ordered another set which i will put one more in the front and check the rear to see if it needs any. This is one thing that kind of put this car down for me was the fact that the diffs didn't mesh properly out of the box made me think i had a defective pair of diffs. I had tried to use a blade to trim the diff yokes but it barely did anything. As i mentioned in previous post i'll eventually upgrade most of the driveline to 4s Outcast\Kraton\Mojave Specs but i might keep the slipper clutch since it's better suited for this platform.Did you do anything to the stock diff housings making sure they had no binding?
I just skimmed over your posts and didn't see any mention of any rotary tool/files being whipped out to get the diffs spinning freely. I know I was skeptical of Vendetta's diff plague, but sure enough, they had so much drag right out of the box. Very, very tight fit.
