Changed my receiver, what channel does ESC and servos go in?
Pmc
On my remote as you can see in attached photos it says channel 3 trim and I could adjust from double zero left and right assuming I should plug the servo the steering and channel 3 then correct? Also what channel should I plug my ESC in the directions do not specify anything it just tells me to connect everything and how to power it on on Traxxas website it says that servo should be plugged into channel 1 I believe and yes he into something else but I’m assuming that is just for a traxxas transmitter not this transmitter as well..? Also in the photos you can see that above channel 3 on the actual transmitter I have a wire plug-in that is a splitter basically for the fan on the engine and for a lightbar on the car that should be fine to plug in there?? Also from the controller and Receiver does anybody know where I can get like a actual owner manual specifics on everything?
Channel one =,servo
channel two = esc
remember, just as edough stated....
1 to turn, two to burn.
