car going backwards
NORRYS
well i bought a starter box and today i went to try to start my rc , i started the engine and the car started to go backwards and as i was using the starter box i thought i had got it wrong so i turned the starter box and kept it the position of the car and I turned it on again and the car just went backwards. If anyone can help me I appreciate it
not a nitro guy but sounds like 1 way bearing is bad
I'm new to rc. but oneway bearing does not stay on the pull start or will there be any more because mine does not have a pullstart I use a starter box, I have a hong nor x1 cr buggy
I don't know maybe it has something to do with the diffs? what do you think??
The one-way bearing has nothing to do with bump starting an engine, I wouldn't worry about that.
It's possible the diffs are backwards, but that would have to have "happened" at some point during a rebuild, it's very unlikely a new model came that way.
Nitro engines can run backwards, but not very well. From the rear of the engine, so that you're facing the same direction as it is, it should turn clockwise.
therealjimmyyy
Replies
9
therealjimmyyy
therealjimmyyy
Marty123c
Replies
5
Marty123c
Marty123c
normrdz300
Replies
4
3K
normrdz300
normrdz300
L
Replies
6
loadedburger
L
