WickedFog
Starter of too many projects
Rig of the Month Winner
- Terre Haute, IN
- Crawling
- Scale Builder
I cannot see these being useful for crawling applications. After installed, depending if you turn them clockwise or counterclockwise, they lock or unlock your axles. When locked you are in 4wd, when you unlock them your front wheels are freewheeling. That is what was featured in older 1:1 trucks. As I said in a previous post, that is the way my Grandpa's old F250 was. The front axles are unlocked, then you turn the hub on the wheels to lock them in and put the truck in 4wd. Nowadays this is done through the transfer case and locking hubs are not needed.
Application: Here is where it would be useful... If you are bashing around or fast trail driving you may want 2wd. Then your rear can slide a bit and you will roll over less than if all 4 wheels were engaged. The Traxxas TRX4 has a feature. You can remote lock/unlock your front and rear axle. When you are in 2wd you can drive faster and corner better.
These are for the rear axles, so you can make the truck front wheel drive only
