To help explain how the low KV rating/high voltage vs high KV/low voltage scenario we will need to establish a couple constants. First, we can only use motors that are within the same series/can size from the same manufacturer. So you can’t compare a Neu motor to a Novak motor, nor can you compare a motor that has a XL can with a motor that has an L can. We will also make the assumption that the ESC used can handle both the voltage and amp draw of either scenario.
Assume you have a car that requires the motor to spin 30,000 rpm to attain a desired speed of 30 mph. To get to 30,000 rpm, let’s say that the required power output is 1000 watts. Here is how different motors/voltages would effect the amp draw. A higher amp draw would require more work from both the ESC and batteries. For sake of discussion, we will exclude voltage drop under load and motor/ESC efficiency in our equations.
Ex.1
Neu 1515 1.5d 2700KV rating
To get to 30,000 RPM, we would require 11.11 volts. (30,000 rpm/2200KV) To get amp draw, we take the power output of 1000 watts and divide that by the voltage. 1000/11.11 volts = 90.01 amps.
Ex.2
Neu 1515 2.5d 1700KV rating
To get to 30,000 RPM, we would require 17.65 volts. (30,000 rpm/1700KV) To get amp draw, we take the power output of 1000 watts and divide that by the voltage. 1000/17.65 volts = 56.66 amps.
As you can see the difference in amp draw is quite a bit. The lower the amp draw, the cooler the esc will run, and the batteries will also stay cooler.
The bad news is that the higher the kV rating the less torque that a motor has.
Not true. Within the same can size of the same manufacturer, the motors will have the same maximum torque output regardless of KV rating.
