i just realised system was made for 2s not 3s, now i gotta send those batterys back when they arrive if i can't cancel order
COMMENTS: When fitted with the Flux Warp 5700 motor or other motors with 5700Kv
of power, you can use up to 7 normal NiMH cells or a 2S LiPo battery.
When fitted with a motor with 4600Kv of power, you can use up to
12 NiMH cells or a 3S LiPo battery
should i return the motor/esc combo and get a 4600 or should i return the lipo's and get a 2s?
i know i quoted myself, i think i got that off hpi's website yesterday, then i read this today
http://www.hpieurope.com/piw.php?lang=en&partNo=100419
The Warp 5700 features:
1. Powerful, high-speed brushless motor
2. Excellent pairing of huge power and extraordinary efficiency
3. Same size as standard 540-size motor
4. Sleek black-anodized aluminium casing
5. Zero maintenance design
6. External solder tabs for easy wire replacement
7. Oversized precision ball bearings for long life
8. High Torque/ High Temperature Neodymium rotor
9. Slotless stator design delivers smooth, linear torque
10. Easy 4-point mounting for convenient installation
11. Longer run times than a comparable brushed motor
12. Easily rebuildable with bearings and rotor being user-replaceable
13. Compatible with any sensorless ESC
*If using an 8-cell NiMH or 3S LiPo battery pack with the Warp 5700, you will need to use a suitably powerful brushless speedo. Please check the spec of the speedo you plan to use. The Motiv can handle 3S LiPo power with a 4600Kv motor, but not 3S power with a 5700Kv motor.
i read this today, it says it can use 3s, i'm stumped...
i called hpi on the phone yesterday he said you can't use 3s at least if i did it wouldn't be warrantied
