Brand new Traxass slash
rayg1022
Just bought a Traxxas Slash and was wondering what additional upgrades can be done to this vehicle?
almost the entire thing from tires to lcg chassis id start with what breaks 1st..maybe upgrade steering rack to a aluminum 1 .. rpm is a good upgrade for parts that break
The sky is the limit my friend. There are sooo many options for the Slash you won't know where to begin. I would suggest first to buy some RPM arms, but don't put them on til you break the stock ones. There are lots of options for shocks, transmission upgrades like 32p pinion and spur, or complete transmissions, LCG chassis, etc. Electronics (especially the servo) can be upgraded. There are also anti-sway bars. There are lots of options for wheels and tires as well.
Like said, you can change all plastics, body hardware, wheels and electronics, you can have a traxxas slash with nothing traxxas.
Wait to see what breaks first then upgrade that to RPM (if not a steering component like a caster block which should be upgraded to aluminum) or aluminum (for caster blocks mainly, AVOID ALUMINUM ARMS!!!).
It's from scratch
That's what is cool about cars with some much aftermarket support. You can just build them. I want to build the UDR from parts off Jenny's RC.
Dont install aluminum A arms or shock towers unless you want to break parts like the chassis mounts. The plastic parts allow enough flexing so things are less likely to break in a crash. You didn't state if it was a 2wd or 4x4.
Am I able to cut the TRX connector for the battery and add something else for a connector for lipo batteries?
Yeah, but I think it voids the warranty 😜
It's worth it though. The Traxxas batteries are overpriced.
It really don't matter does it? If you can pretty much replace any part right?
Yeah. Don't sweat it. You can replace everything pretty cheap on it. I'm not sure really on the warranty. Kevin Talbot on YT always cuts them off first thing and makes the comment "void the warranty".
I can still use thier ESC right, I think I seen a video where you connect the lipo battery and hold the button down on the ESC until it turns green?
If you change the connector, nothing else would change except for the connector. You can still use the ESC normally, Green = LVC on, Red = LVC off.
Right, you need to make sure the ESC is in the green right before use? Do I need to do that all the time?
The settings will stay the same unless you change them.
In the box they gave another gear setup for faster speeds, is another?
I don't understand your question. The speed gearing is only for straight-line speed runs with breaks in between.
