I'll explain precisely what I did...
1. Removed roto-start backplate.
2. put 10mm socket on the roto-start shaft hex
3. put cross wrench on flywheel nut
4. Tightened... popped HARD (previous to this, there were no issues getting the flywheel nut tight[er] as this was like the 4th attempt at getting the flywheel to keep from slipping. At this point the flywheel nut is tight and the flywheel is firm to the crankshaft. I just overdid it, totally my fault.
5. Testing.. at this point everytime I put torque on the flywheel nut, it "pop-slips" easily
6. Took entire roto-start apart and cleaned one-way/shaft etc.
7. Put everything back together
8. Tried turning over engine with freshly charged drill. Turns roto-start but will not turn over engine.
Randy, thanks for the offer fine sir. However, I've already pulled the one-way out and found the proper bearing at BocaBearings website. I just put my order in. $15 free shipping. Just gotta figure out how I'm going to pull the bearing out of the casing.
The small engraving says HF0812 which is what I searched for. 8x12x12. Common use was stated as r/c car so I figured it was a fair gamble. Now, do I press it out the top or bottom? I assume top as that's most likely the direction it went in from??
