thatcraig
So I keep trying to bind my controller to my truck but it isn't doing it. I hit the bind button on the sec and then I click the bind button on the radio, but nothing happens. Can anyone tell how to bind the truck?
You are not giving us enough information to help.I have no steering
I have no steering now that I checked...Normally you bind the Rx to the Tx on the Radio
The ESC gets calibrated separately to set the throttle.
Can you confirm you have steering working first?
If so then you simply need to calibrate the ESC.
Every brand is different, so need to know which brand of ESC or you can search YouTube yourself for a demo on how to calibrate your brand of ESC.
You still havent answered this basic question.Need to know brand of radio and brand of ESC.
Since I still dont know what Spektrum radio system you are using all I can do is give you a video link to a random Spektrum model and hope it works for whatever model you have. I would suggest, if this doesn't work, then you need to find out the exact model of radio and receiver you are using and look for videos or instructions online on how to bind that specific model.I have a firma esc and and a spectrum radio
The ESC has nothing to do with steering unless the BEC went bad and isnt sending power to the receiver. Check the voltage on the positive and negative pins of channel one on your receiver with the rig powered on. Is it reading the proper voltage?Alright then Idk what the problem is, the truck doesn't steer though, so does this indicate my esc is bad?
I have no throttle either, and idk how to tell what channel the steering is plugged into.The ESC has nothing to do with steering unless the BEC went bad and isnt sending power to the receiver. Check the voltage on the positive and negative pins of channel one on your receiver with the rig powered on. Is it reading the proper voltage?
Do you have throttle?
What channel is the steering servo plugged in to?
Can you post a link to a good voltage tester I could buy?It will be labeled. Sometimes it will say CH1 CH2 etc, or it might say STR for steering or THR for Throttle. At this point you need to check the voltage on any of the channels. they will all be the same voltage so it doesn't matter which channel you check. You will want to check the 2 pins that are on the outside edge of the receiver.
Really for what you're going to use it for you could buy any ole voltmeter. If you want a good one, then buy one from Fluke but thats gonna run you $100 minimum.Can you post a link to a good voltage tester I could buy?
What does aux power ?Alright I bought a volt meter and when it comes in ill check the voltage.
Or what does it do so I know what I can plug into it?Alright I bought a volt meter and when it comes in ill check the voltage.
